_________________________________________________________________________________________________________
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:00:22 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-7G6T94E
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: System Product Name, ASUS
BIOS: 2701
CPU: GenuineIntel Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 32668 MB total
CPU SPEED
Reported CPU speed (WMI): 3792 MHz
Reported CPU speed (registry): 3792 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 388,40
Average measured interrupt to process latency (µs): 5,625569
Highest measured interrupt to DPC latency (µs): 386,40
Average measured interrupt to DPC latency (µs): 2,253938
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 241,403481
Driver with highest ISR routine execution time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,001732
Driver with highest ISR total time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,002493
ISR count (execution time <250 µs): 7222
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1073,816983
Driver with highest DPC routine execution time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0,032886
Driver with highest DPC total execution time: Wdf01000.sys - Runtime framework driver modalità kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,070014
DPC count (execution time <250 µs): 25565
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 42
DPC count (execution time 1000-2000 µs): 2
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: backgroundtaskhost.exe
Total number of hard pagefaults 548
Hard pagefault count of hardest hit process: 430
Number of processes hit: 5
PER CPU DATA
CPU 0 Interrupt cycle time (s): 1,803638
CPU 0 ISR highest execution time (µs): 241,403481
CPU 0 ISR total execution time (s): 0,007377
CPU 0 ISR count: 4954
CPU 0 DPC highest execution time (µs): 1073,816983
CPU 0 DPC total execution time (s): 0,226410
CPU 0 DPC count: 22988
CPU 1 Interrupt cycle time (s): 1,267395
CPU 1 ISR highest execution time (µs): 24,754219
CPU 1 ISR total execution time (s): 0,000604
CPU 1 ISR count: 715
CPU 1 DPC highest execution time (µs): 221,321730
CPU 1 DPC total execution time (s): 0,012751
CPU 1 DPC count: 740
CPU 2 Interrupt cycle time (s): 1,013356
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR total execution time (s): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 77,917194
CPU 2 DPC total execution time (s): 0,001120
CPU 2 DPC count: 209
CPU 3 Interrupt cycle time (s): 1,154146
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 1,094937
CPU 3 DPC total execution time (s): 0,000001
CPU 3 DPC count: 1
CPU 4 Interrupt cycle time (s): 1,037722
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 526,553797
CPU 4 DPC total execution time (s): 0,001983
CPU 4 DPC count: 266
CPU 5 Interrupt cycle time (s): 1,231653
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 6,167194
CPU 5 DPC total execution time (s): 0,000009
CPU 5 DPC count: 4
CPU 6 Interrupt cycle time (s): 1,085570
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 57,686709
CPU 6 DPC total execution time (s): 0,000852
CPU 6 DPC count: 349
CPU 7 Interrupt cycle time (s): 1,051688
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 54,349684
CPU 7 DPC total execution time (s): 0,000159
CPU 7 DPC count: 14
CPU 8 Interrupt cycle time (s): 0,411630
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 508,892405
CPU 8 DPC total execution time (s): 0,000675
CPU 8 DPC count: 84
CPU 9 Interrupt cycle time (s): 0,547349
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 3,569093
CPU 9 DPC total execution time (s): 0,000004
CPU 9 DPC count: 2
CPU 10 Interrupt cycle time (s): 0,463834
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 57,407173
CPU 10 DPC total execution time (s): 0,000634
CPU 10 DPC count: 272
CPU 11 Interrupt cycle time (s): 0,520520
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 14,351793
CPU 11 DPC total execution time (s): 0,000101
CPU 11 DPC count: 24
CPU 12 Interrupt cycle time (s): 0,550750
CPU 12 ISR highest execution time (µs): 2,255274
CPU 12 ISR total execution time (s): 0,000020
CPU 12 ISR count: 35
CPU 12 DPC highest execution time (µs): 15,53270
CPU 12 DPC total execution time (s): 0,000249
CPU 12 DPC count: 107
CPU 13 Interrupt cycle time (s): 0,639809
CPU 13 ISR highest execution time (µs): 20,681962
CPU 13 ISR total execution time (s): 0,000654
CPU 13 ISR count: 1345
CPU 13 DPC highest execution time (µs): 54,403481
CPU 13 DPC total execution time (s): 0,000275
CPU 13 DPC count: 50
CPU 14 Interrupt cycle time (s): 1,060705
CPU 14 ISR highest execution time (µs): 2,353376
CPU 14 ISR total execution time (s): 0,000011
CPU 14 ISR count: 20
CPU 14 DPC highest execution time (µs): 44,171414
CPU 14 DPC total execution time (s): 0,000937
CPU 14 DPC count: 427
CPU 15 Interrupt cycle time (s): 1,182701
CPU 15 ISR highest execution time (µs): 5,894515
CPU 15 ISR total execution time (s): 0,000113
CPU 15 ISR count: 153
CPU 15 DPC highest execution time (µs): 33,549051
CPU 15 DPC total execution time (s): 0,000455
CPU 15 DPC count: 72
