_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:02:58 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-7G6T94E
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: System Product Name, ASUS
BIOS: 2701
CPU: GenuineIntel Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 32668 MB total
CPU SPEED
Reported CPU speed (WMI): 3792 MHz
Reported CPU speed (registry): 3792 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 2098,10
Average measured interrupt to process latency (µs): 4,583485
Highest measured interrupt to DPC latency (µs): 2095,30
Average measured interrupt to DPC latency (µs): 2,198919
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 63,370781
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000821
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,001148
ISR count (execution time <250 µs): 17093
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 618,223101
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 536.40 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,059694
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,131511
DPC count (execution time <250 µs): 567437
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 40
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: fifa23.exe
Total number of hard pagefaults 127620
Hard pagefault count of hardest hit process: 104997
Number of processes hit: 69
PER CPU DATA
CPU 0 Interrupt cycle time (s): 11,093287
CPU 0 ISR highest execution time (µs): 45,733122
CPU 0 ISR total execution time (s): 0,007288
CPU 0 ISR count: 3617
CPU 0 DPC highest execution time (µs): 618,223101
CPU 0 DPC total execution time (s): 3,381096
CPU 0 DPC count: 489531
CPU 1 Interrupt cycle time (s): 1,869335
CPU 1 ISR highest execution time (µs): 63,370781
CPU 1 ISR total execution time (s): 0,022878
CPU 1 ISR count: 9830
CPU 1 DPC highest execution time (µs): 121,198840
CPU 1 DPC total execution time (s): 0,143671
CPU 1 DPC count: 12560
CPU 2 Interrupt cycle time (s): 1,101510
CPU 2 ISR highest execution time (µs): 9,910865
CPU 2 ISR total execution time (s): 0,000325
CPU 2 ISR count: 154
CPU 2 DPC highest execution time (µs): 299,939346
CPU 2 DPC total execution time (s): 0,019717
CPU 2 DPC count: 6997
CPU 3 Interrupt cycle time (s): 1,156191
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 53,899789
CPU 3 DPC total execution time (s): 0,012894
CPU 3 DPC count: 4182
CPU 4 Interrupt cycle time (s): 1,696641
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 159,264768
CPU 4 DPC total execution time (s): 0,041359
CPU 4 DPC count: 10955
CPU 5 Interrupt cycle time (s): 1,063723
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 87,324895
CPU 5 DPC total execution time (s): 0,005509
CPU 5 DPC count: 1825
CPU 6 Interrupt cycle time (s): 1,074467
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 88,101793
CPU 6 DPC total execution time (s): 0,014771
CPU 6 DPC count: 5306
CPU 7 Interrupt cycle time (s): 1,014123
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 95,485232
CPU 7 DPC total execution time (s): 0,005786
CPU 7 DPC count: 2080
CPU 8 Interrupt cycle time (s): 1,028521
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 298,213080
CPU 8 DPC total execution time (s): 0,014229
CPU 8 DPC count: 4760
CPU 9 Interrupt cycle time (s): 1,206555
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 297,811709
CPU 9 DPC total execution time (s): 0,023148
CPU 9 DPC count: 5948
CPU 10 Interrupt cycle time (s): 1,026988
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 298,939346
CPU 10 DPC total execution time (s): 0,016438
CPU 10 DPC count: 5603
CPU 11 Interrupt cycle time (s): 1,029327
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 156,187764
CPU 11 DPC total execution time (s): 0,008020
CPU 11 DPC count: 2246
CPU 12 Interrupt cycle time (s): 1,309212
CPU 12 ISR highest execution time (µs): 2,667722
CPU 12 ISR total execution time (s): 0,001156
CPU 12 ISR count: 1644
CPU 12 DPC highest execution time (µs): 298,186709
CPU 12 DPC total execution time (s): 0,027026
CPU 12 DPC count: 6750
CPU 13 Interrupt cycle time (s): 1,114930
CPU 13 ISR highest execution time (µs): 3,315928
CPU 13 ISR total execution time (s): 0,000910
CPU 13 ISR count: 1547
CPU 13 DPC highest execution time (µs): 143,633439
CPU 13 DPC total execution time (s): 0,006338
CPU 13 DPC count: 1957
CPU 14 Interrupt cycle time (s): 1,139541
CPU 14 ISR highest execution time (µs): 1,421941
CPU 14 ISR total execution time (s): 0,000031
CPU 14 ISR count: 34
CPU 14 DPC highest execution time (µs): 183,864979
CPU 14 DPC total execution time (s): 0,020720
CPU 14 DPC count: 5131
CPU 15 Interrupt cycle time (s): 1,175476
CPU 15 ISR highest execution time (µs): 1,274262
CPU 15 ISR total execution time (s): 0,000158
CPU 15 ISR count: 267
CPU 15 DPC highest execution time (µs): 111,522679
CPU 15 DPC total execution time (s): 0,009332
CPU 15 DPC count: 1646
