EmanueleC
Utente Èlite
- Messaggi
- 5,784
- Reazioni
- 1,913
- Punteggio
- 168
Provate con il kernel che fornisce questo utente, sembra che ha una patch e dovrebbe funzionare: Sound Blaster Z, Zx, ZxR Linux test-patch
sbz_linux.jpgAnd yeah, this means you have to compile the Linux kernel yourself in order to test this patch, either build from my repo or cherrypick the patch and build with your kernel, unless you're under Ubuntu (64 bit) for which i can provide a prebuilt kernel.
Updated Patch Link:
GitHub
What works:
- Line out (mid jack)
- Mic in (1st jack)
What does not work:
- Everything else...
Bugs:
- Possible distorted mic in:
Fix: Turn your PC off and remove the power, then turn it back on.
Confirmed Working:
Sound Blaster Z (SSID 0x1102:0010)
Sound Blaster Z (SSID 0x1102:0027)
Sound Blaster Zx (SSID 0x1102:0025)
Possibly Works:
Sound Blaster Z (SSID 0x1102:0023)
Sound Blaster Z (SSID 0x1102:0024)
Not Working:
Sound Blaster ZxR (SSID 0x1102:0033)
Prebuilt Kernel for Ubuntu 64 bit:
Dropbox
Please test, thanks. I still have doubts about ZxR so if it does not work for you please provide some information about your system, kernel dmesg and alsa-info, and make sure you booted the right kernel![]()
