Che modello è il pc? Così vediamo se si trova qualcosa in rete.
Postaci l'output dei comandi lspci e di lshw. Non è detto che si riesca a risolvere, potrebbero essere incompleti i driver Linux per le tue periferiche e che non se ne trovino di migliori
Asus P550LAV
francesco@Avv:~$ sudo lspci
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
00:04.0 Signal processing controller: Intel Corporation Device 0a03 (rev 0b)
00:14.0 USB controller: Intel Corporation Lynx Point-LP USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation Lynx Point-LP HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation Lynx Point-LP HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 1 (rev e4)
00:1c.2 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation Lynx Point-LP PCI Express Root Port 4 (rev e4)
00:1d.0 USB controller: Intel Corporation Lynx Point-LP USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Lynx Point-LP LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Lynx Point-LP SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Lynx Point-LP SMBus Controller (rev 04)
00:1f.6 Signal processing controller: Intel Corporation Lynx Point-LP Thermal (rev 04)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device 5287 (rev 01)
02:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
03:00.0 Network controller: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe
03:00.1 Bluetooth: Ralink corp. RT3290 Bluetooth
francesco@Avv:~$ sudo lshw
avv
description: Notebook
product: X550LA (ASUS-NotebookSKU)
vendor: ASUSTeK COMPUTER INC.
version: 1.0
serial: E8NXCV467235356
width: 64 bits
capabilities: smbios-2.7 dmi-2.7 vsyscall32
configuration: boot=normal chassis=notebook family=X sku=ASUS-NotebookSKU uuid=C052D37E-137C-F581-2DD5-382C4A0B2411
*-core
description: Motherboard
product: X550LA
physical id: 0
version: 1.0
serial: BSN12345678901234567
slot: MIDDLE
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: X550LA.508
date: 05/14/2014
capacity: 6080KiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification uefi
*-cpu
description: CPU
product: Intel(R) Core(TM) i3-4030U CPU @ 1.90GHz
vendor: Intel Corp.
physical id: 7
bus info: cpu@0
version: Intel(R) Core(TM) i3-4030U CPU @ 1.90GHz
slot: SOCKET 0
capacity: 3800MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm arat epb pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid xsaveopt cpufreq
configuration: cores=2 enabledcores=2 threads=4
*-cache:0
description: L2 cache
physical id: 8
slot: CPU Internal L2
capacity: 512KiB
capabilities: internal write-back unified
*-cache:1
description: L1 cache
physical id: 9
slot: CPU Internal L1
capacity: 128KiB
*-cache:2
description: L3 cache
physical id: a
slot: CPU Internal L3
capacity: 3MiB
*-memory
description: System Memory
physical id: b
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1600 MHz (0,6 ns)
vendor: Samsung
physical id: 0
serial: 00000000
slot: ChannelA-DIMM0
width: 64 bits
clock: 1600MHz (0.6ns)
*-bank:1
description: DIMM [empty]
product: [Empty]
vendor: [Empty]
physical id: 1
serial: [Empty]
slot: ChannelA-DIMM1
*-bank:2
product: [Empty]
vendor: [Empty]
physical id: 2
serial: [Empty]
slot: ChannelB-DIMM0
*-bank:3
product: [Empty]
vendor: [Empty]
physical id: 3
serial: [Empty]
slot: ChannelB-DIMM1
*-pci
description: Host bridge
product: Haswell-ULT DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 0b
width: 32 bits
clock: 33MHz
*-display
description: VGA compatible controller
product: Haswell-ULT Integrated Graphics Controller
physical id: 2
bus info: pci@0000:00:02.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:46 memory:f7800000-f7bfffff memory:e0000000-efffffff ioport:f000(size=64)
*-multimedia:0
description: Audio device
product: Haswell-ULT HD Audio Controller
physical id: 3
bus info: pci@0000:00:03.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:49 memory:f7e1c000-f7e1ffff
*-generic:0 UNCLAIMED
description: Signal processing controller
product: Intel Corporation
physical id: 4
bus info: pci@0000:00:04.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list
configuration: latency=0
resources: memory:f7e10000-f7e17fff
*-usb:0
description: USB controller
product: Lynx Point-LP USB xHCI HC
physical id: 14
bus info: pci@0000:00:14.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:42 memory:f7e00000-f7e0ffff
*-communication
description: Communication controller
product: Lynx Point-LP HECI #0
physical id: 16
bus info: pci@0000:00:16.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: irq:47 memory:f7e25000-f7e2501f
*-multimedia:1
product: Lynx Point-LP HD Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 04
width: 64 bits
clock: 33MHz
resources: irq:48 memory:f7e18000-f7e1bfff
*-pci:0
description: PCI bridge
product: Lynx Point-LP PCI Express Root Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: e4
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:16
*-pci:1
product: Lynx Point-LP PCI Express Root Port 3
physical id: 1c.2
bus info: pci@0000:00:1c.2
version: e4
width: 32 bits
clock: 33MHz
resources: irq:18 ioport:e000(size=4096) memory:f7d00000-f7dfffff
*-generic
description: Unassigned class
product: Realtek Semiconductor Co., Ltd.
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list rom
configuration: driver=rtsx_pci latency=0
resources: irq:43 memory:f7d15000-f7d15fff memory:f7d00000-f7d0ffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0.1
bus info: pci@0000:02:00.1
logical name: eth0
version: 12
serial: 38:2c:4a:0b:24:11
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8411-2_0.0.1 07/08/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:45 ioport:e000(size=256) memory:f7d14000-f7d14fff memory:f7d10000-f7d13fff
*-pci:2
product: Lynx Point-LP PCI Express Root Port 4
physical id: 1c.3
bus info: pci@0000:00:1c.3
version: e4
width: 32 bits
clock: 33MHz
resources: irq:19 memory:f7c00000-f7cfffff
*-network
description: Wireless interface
product: RT3290 Wireless 802.11n 1T/1R PCIe
vendor: Ralink corp.
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlan0
version: 00
serial: b0:10:41:a5:55:2d
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rt2800pci driverversion=3.18.1-031801-generic firmware=0.37 ip=192.168.0.5 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
resources: irq:19 memory:f7c10000-f7c1ffff
*-generic UNCLAIMED
description: Bluetooth
product: RT3290 Bluetooth
physical id: 0.1
bus info: pci@0000:03:00.1
version: 00
width: 32 bits
clock: 33MHz
resources: memory:f7c00000-f7c0ffff
*-usb:1
product: Lynx Point-LP USB EHCI #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=0
resources: irq:23 memory:f7e23000-f7e233ff
*-isa
description: ISA bridge
product: Lynx Point-LP LPC Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
*-storage
description: SATA controller
product: Lynx Point-LP SATA Controller 1 [AHCI mode]
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 04
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:44 ioport:f0b0(size=8) ioport:f0a0(size=4) ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:f7e22000-f7e227ff
*-serial UNCLAIMED
description: SMBus
product: Lynx Point-LP SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 04
width: 64 bits
clock: 33MHz
resources: memory:f7e21000-f7e210ff ioport:f040(size=32)
*-generic:1 UNCLAIMED
product: Lynx Point-LP Thermal
physical id: 1f.6
bus info: pci@0000:00:1f.6
version: 04
width: 64 bits
clock: 33MHz
resources: memory:f7e20000-f7e20fff
*-scsi:0
physical id: 1
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: TOSHIBA MQ01ABF0
vendor: Toshiba
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 1J
serial: 44MFC7HQT
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=1df98874-870e-44b7-8f6c-50735b53bf85 sectorsize=4096
*-volume:0 UNCLAIMED
description: Windows FAT volume
vendor: MSDOS5.0
physical id: 1
bus info: scsi@0:0.0.0,1
version: FAT32
serial: 7c51-1c7e
capacity: 99MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat name=EFI system partition
*-volume:1
description: Windows NTFS volume
vendor: Windows
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
version: 3.1
serial: 3e45-d446
capacity: 899MiB
capabilities: boot precious readonly hidden nomount ntfs initialized
configuration: clustersize=4096 created=2014-09-01 07:40:43 filesystem=ntfs label=Recovery name=Basic data partition state=clean
*-volume:2
description: reserved partition
vendor: Windows
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
serial: f8696fba-009a-408b-8b57-25d236ec2975
capacity: 127MiB
capabilities: nofs
configuration: name=Microsoft reserved partition
*-volume:3
vendor: Windows
physical id: 4
bus info: scsi@0:0.0.0,4
logical name: /dev/sda4
version: 3.1
serial: d4563958-5f34-7a44-a92c-fb64f7b16b2f
capacity: 186GiB
capabilities: ntfs initialized
configuration: clustersize=4096 created=2014-09-01 07:40:48 filesystem=ntfs label=OS name=Basic data partition state=clean
*-volume:4
vendor: Windows
physical id: 5
bus info: scsi@0:0.0.0,5
logical name: /dev/sda5
version: 3.1
serial: 3eb719db-d9bc-7948-a30f-463c9dbb64c1
capacity: 158GiB
configuration: clustersize=4096 created=2014-09-01 07:40:51 filesystem=ntfs label=Data name=Basic data partition state=clean
*-volume:5
vendor: Windows
physical id: 6
bus info: scsi@0:0.0.0,6
logical name: /dev/sda6
version: 3.1
serial: 4c4c-a2cb
capacity: 20GiB
configuration: clustersize=4096 created=2014-09-01 07:40:54 filesystem=ntfs label=Restore modified_by_chkdsk=true mounted_on_nt4=true name=Basic data partition resize_log_file=true state=dirty upgrade_on_mount=true
*-volume:6
description: Linux swap volume
vendor: Linux
physical id: 7
bus info: scsi@0:0.0.0,7
logical name: /dev/sda7
version: 1
serial: 48efac46-aa26-4532-82b8-784aec3f1f77
capacity: 3905MiB
capabilities: nofs swap initialized
configuration: filesystem=swap pagesize=4095
*-volume:7
description: EXT4 volume
vendor: Linux
physical id: 8
bus info: scsi@0:0.0.0,8
logical name: /dev/sda8
logical name: /
version: 1.0
serial: 8ed1c809-c529-4236-9822-18d5872fc064
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2014-12-30 02:37:35 filesystem=ext4 lastmountpoint=/ modified=2015-01-07 14:17:34 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2015-01-07 14:17:35 state=mounted
*-volume:8
vendor: Linux
physical id: 9
bus info: scsi@0:0.0.0,9
logical name: /dev/sda9
logical name: /home
version: 1.0
serial: 110875f2-b2f7-45ce-b09d-762563f6c927
configuration: created=2014-12-30 02:37:38 filesystem=ext4 lastmountpoint=/home modified=2015-01-07 14:17:35 mount.fstype=ext4 mount.options=rw,relatime,data=ordered mounted=2015-01-07 14:17:35 state=mounted
*-scsi:1
physical id: 2
logical name: scsi1
*-cdrom
description: DVD-RAM writer
product: DVD A DA8A5SH-L
vendor: Slimtype
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/sr0
version: RAA1
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
francesco@A
