- 1,760
- 81
- CPU
- INTEL CORE I7 8700K Delid 5 Ghz - 1.285 vcore
- Dissipatore
- NZXT KRAKEN X62 - 280mm
- Scheda Madre
- ASUS MAXIMUS XI EXTREME
- HDD
- 2 SAMSUNG M2 970 Pro 512gb + 850 Pro 256 Gb + 840 Pro 128gb + WD Caviar BLACK 1 TB
- RAM
- Corsair Vengeance LED 4K 3200 Mhz
- GPU
- NVIDIA ASUS STRIX RTX 2080ti - 11 Gb
- Audio
- SOUND BLASTER ZX
- Monitor
- 3 ASUS ROG SWIFT 25" PG258Q - 1ms - GSYNC
- PSU
- CORSAIR AX860i - 80+ PLATINUM
- Case
- CORSAIR Obsdian 1000D
- OS
- Windows 10 PRO 64 Bit
Ciao a tutti
vi chiedo una mano perche'non so piu'dove sbattere la testa e sono disperato... :muro:
Ho una Maximus IX Formula e le RAM Corsair Vengeance 4K Led 3200 Mhz....e nelle ultime settimane se lascio il pc idle, me lo ritrovo riavviato...
controllando whocrashed mi da che cé stata una schermata blu con questo risultato...
On Mon 26/03/2018 13:38:18 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\032618-4937-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x175510)
Bugcheck code: 0x4E (0x99, 0x102DF4, 0x2, 0xE00010000102DF3)
Error: PFN_LIST_CORRUPT
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!PsChargeProcessNonPagedPoolQuota+0x85A5)
La CPU e'un I7 7700K in OC a 4.8 con 1.350 di vcore ma continui test con IBT su MAXIMUM (che durano ore) e gaming bello pesante non danno segni di instabilita'.
Le RAM sono con profilo XMP a 3000mhz xche a 3200 il pc mi crasha di continuo....
Tutto e'cominciato la settimana scorsa quando la scheda wifi Atheros integrata ha deciso di abbandonarmi....prima non trovando piu le reti wifi e dopo scomparendo definitivamente ed ora sto usando il cavo ethernet....
Non so se i due casi sono collegati ma i problemi dei BSOD in Idle sono cominciati da li....
Su consiglio di un amico questa mattina ho fatto partire memtestx86 all avvio usando la chiavetta USB, sempre con le RAM a 3000mhz in XMP...
Torno dopo 3 ore e mi ritrovo 2 errori.....Panico....
Allora provo a mettere il profilo delle RAM in AUTO anziche'XMP 3000
Faccio partire memtestx86 e lo lascio andare x 6 ore fino a quando non completa il test.....
RISULTATO: NESSUN ERRORE...
Ora vorrei capire....ma le RAM sono guaste o mi creano problemi solo se imposto XMP e mi fanno crashare il pc quando e'in idle?
Puo'essere la scheda madre e i suoi voltaggi (visto che a volte se metto una chiavetta USB nel pannello frontale 3.0 del case non mi entra nel bios o si blocca sul logo ROG senza fare il Boot)
Puo'essere l alimentatore (Corsair AX760i)?
Vi chiedo gentilmente di darmi una mano a capire xche se devo sostituire qualche pezzo lo faccio. Sono disperato amici...
Ringrazio tutti in anticipo
Francesco
Francesco
