Hi to all.
I have install in my old case(ac 97 audio) this mainboard: https://www.gigabyte.com/Motherboard/GA-B85M-D3V-rev-21/support#support-dl-driver
So i have connect the 5 connector ac97 to the motherboard F_audio connector following the manual : 1MIC yellow, 2 GND black, 3mic power red, 5 R green 9 L orange but front panel jack not work, if i insert jack windows not recognize it.
So i think that i must change configuration on the bios from HD Audio (default) to AC 97 but i can't found any option.
p.S i have windows 10 x64 with installed old driver ,i have also install Audio driver from the link upper, Realtek HD Audio Driver [7727] with his control panel, but not recognize jack headphone insert on front panel.
Can we help me?
thanks
Edit , i have resolve it: click the tool icon on the Audio I/O tab On the Global Connector Settings box, select the Disable front panel jack detection check box. Click OK to activiate the AC'97 functionality.
bye!
Can we help me?
thanks
Post unito automaticamente:
bye!
