PROBLEMA AIUTO, ASUS MAXIMUS V EXTREME 1155 PROBLEMI VOLTS VGA
carlitoscrackoem
CPU
intel i7 960
Scheda Madre
ASUS P6X58D-E
HDD
CORSAIR FORCE GT 120GB SATA3
RAM
PATRIOT SECTOR 6GB 2000MHZ PV736G2000ELK
GPU
SLI GTX 580 1,5GB ASUS
Audio
INTEGRATA
Monitor
24 " HD 1080P
PSU
1000W COOLER MASTER 80A
Case
COOLMASTER NVIDIA
OS
WINDOWS 7 64 BIT
CIAO A TUTTI VI SCRIVO PER CHIEDERE INFORMAZIONI E AIUTO SU QUESTA SCHEDA , DUNQUE ECCO IL MIO PROBLEMA:
IMPOSTANDO DAL BIOS O DA QUALUNQUE PARTE DELLA SCHEDA MADRE I SETTAGGI PER DARMI UN USCITA I VOLTAGGI DELLA SCHEDA VIDEO ,(ASUS NVIDIA GTX 680 DC2T ) CHE SONO STATI SALDATI E COLLAUDATI I CONETTORI TRA SCHEDA MADRE E SCHEDA VIDEO (VTT,RAM,GPU) RIESCO SOLTANTO A VISUALIZARE E MONITORARE I VOLTAGGI, ANCHE SE PROVO AD AUMENTARE I VOLTAGGI DI TUTTE 3 VTT,RAM,GPU NON LI AUMENTA CONTINUA CON SUOI VOLTAGGI DI DEFAULT , QUALCUNO SA DIRMI SE CE QUALCHE TASTO O MORSETTO DA MUOVERE O DAL BIOS PER DAR VOLTAGGI IN USCITA.. CHE CON IL MULTIMETRO (TESTER VOLT) MI RISULTA 0 VOLT IN USCITA SIA IN VTT CHE IN GPU E IN RAM
naruto80
Utente Èlite
17,384
2,834
CPU
intel i5 6600k@45x
Dissipatore
liquido
Scheda Madre
Gigabyte Z170 Gaming 5
HDD
samsung 850 pro 512gb + ocz arc 240gb + WD Red 2TB + WD Black 1TB
RAM
4x4GB PANRAM 3000C15
GPU
Sapphire 390X Tri-X OC
Audio
integrato+creative i-trigue 3330+ CM Storm sirus 5.1
Monitor
Asus MG279Q
PSU
evga GQ 850W
Case
Xigmatek Elisyum
Periferiche
Gskill KM780 & Gskill MX 780 RGB
OS
win 10 pro 64bit
La tua vga è overvoltabile?....a me sembra di no....ma comunque stai usando l oc key?
Sinceramente ho capito poco di quello che volevi dire....tipo in che senso saldati?
carlitoscrackoem
CPU
intel i7 960
Scheda Madre
ASUS P6X58D-E
HDD
RAM
GPU
Audio
INTEGRATA
Monitor
24 " HD 1080P
PSU
Case
COOLMASTER NVIDIA
OS
WINDOWS 7 64 BIT
SCUSAMI SE NON MI SONO FATTO CAPIRE BENE ALLORA:
LA SCHEDA VIDEO E LA ASUS GTX 680 DC2T KE HA A DISPOSIZIONE I 6 BUCCHI DA SADARE DEI CONNETTORI E COSI COLLEGARLA ALLA SCHEDA MADRE DUNQUE I 6 CONETTORI SAREBBERO 3 PER INTRODURRE VOLTAGGIO AUXILIARE VGA,VTT,RAM E GLI ALTRI 3 PER MONITORARE I VOLTAGGI CHE ARRIVANO DALLA SCHEDA VIDEO ALLA SCHEDA MADRE..
PER QUANTO RIGUARDA I MONITORAGGIO IO RIESCO A VISUALIZZARLI SENZA PROBLEMA MA SE PROVO AD AUMENTARE I VOLTAGGI VGA VTT RAM NON CAMBIA NULLA CIOE COME SE NON AUMENTASSE IL VOLTAGGIO RIMANI SEMPRE LO STESSO VOLTAGGIO STANDAR DELLA SCHEDA VIDEO ORA PERO SONO ANDATO AL NEGOZIO DOVE LO COMPRATA LA SCHEDA MADRE E MI HANNO DETTO CHE TRA DUE GIORNI MI PORTERANNO UNA SECONDA SCHEDA MADRE PER VEDERE SE SUCCEDE LO STESSO CON QUESTA... IO LO SPERO CHE SIA LA SCHEDA MADRE ANCHE PERCHE SALDANDO I CONNETTORI SULLA SCHEDA VIDEO SI VA A PERDERE LA GARANZIA ..
mr.frizz
Utente Grafene
Utente Èlite
93,236
17,851
CPU
i7 2600k@4.5
Dissipatore
truespirit 140
Scheda Madre
msi z77a-g45
HDD
500 spinpoint f3 + 840 pro 256 + sandisk ultraII 240
RAM
2*4gb tridentZ 2133 cl9
GPU
Sapphire Rx 580 nitro oc+ 4GB
Audio
integrata
Monitor
lg m2232
PSU
corsair tx650v1
Case
Corsair 300r WW
OS
7 ultimate 64
per comodità scrivi minuscolo, è più leggibile ;)
per il resto,hai verificato con un tester se le tensioni corrispondono?
carlitoscrackoem
CPU
intel i7 960
Scheda Madre
ASUS P6X58D-E
HDD
RAM
GPU
Audio
INTEGRATA
Monitor
24 " HD 1080P
PSU
Case
COOLMASTER NVIDIA
OS
WINDOWS 7 64 BIT
allora ho controllato con il tester dove ci sono i 3 connettori vga vtt ram per verificare i voltaggi e mi da come risultato 1,21 Gpu ,1,54 Ram, e 1.054 vtt, ora se vado ad aumentare i voltaggi dal solito oc key lo faccio pero nel tester mi risulta gli stessi voltaggi , come se non avesse modificato nulla , invece dovrebbe aumentare i voltaggi a seconda che modifico i voltaggi dalla oc key .
e magari un guasto della scheda madre ?
poi ogni tanto quando spengo il computer o accedo mi compare schermata blu ed è una cosa molto strada dato che con le altre schede madri non mi succedeva lo esteso.
mr.frizz
Utente Grafene
Utente Èlite
93,236
17,851
CPU
i7 2600k@4.5
Dissipatore
truespirit 140
Scheda Madre
msi z77a-g45
HDD
RAM
GPU
Audio
integrata
Monitor
lg m2232
PSU
corsair tx650v1
Case
Corsair 300r WW
OS
7 ultimate 64
quindi non sta aumentando...non è che devi cambiare bios?
Entra
oppure Accedi utilizzando
Discord Ufficiale Entra ora!
Discussioni Simili
